Hack for LOEWE XEMIX 5106DO
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by mtone@btinterne, Sep 25, 2004.
  1. mtone@btinterne
    mtone@btinterne
    Anyone know if it is possible to make this DVD player multi region via a handset hack or any other way.
    :lease: :lease: :lease:
  2. alscds
    alscds
    the technology in the loewe is philips/lg..... i only have one hack for loewe
    open the draw then press zero 7 times a message should be displayed.. hope this helps
  3. Gerard Fernand
    Gerard Fernand
    Jul 31, 2004
    207
    28
    Livingston, Scotland
    +29
    As far as I know this is an up to date hack for the current range, not tried it yet.
    Press PAUSE
    then 314159 to bring up menu
    select region
    press PAUSE to exit
  4. steve2505
    steve2505
    In order to make the Loewe region free you need a One for all remote
    :lesson:
    I used a URC 7560 and set the remote up to control the DVD (setup code 0539)
    then I pressed the DVD button
    then I pressed the magic button
    then I pressed 085
    Now those dashes appear (the ones you get by pressing play 159 ... but don't do it :suicide: )
    then key in 222 222 005 255 play
    your loewe is region free
    this worked on my Loewe Xemix 5006DD :clap: :clap: :clap:
    Steve
  5. ChristianB
    ChristianB
    The code that Gerrard suggested works fine, at least it did for my Xemix 6122
    Press PAUSE
    select region
    press PAUSE to exit
