Hack for a LOEWE XEMIX6122
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by DarrenH, Jul 23, 2004.
  1. DarrenH
    DarrenH
    Jul 20, 2004
    577
    Kent
    +7
    Have been looking at buying the Loewe Aventos 3781 package from Comets which includes a stand and a Loewe XEMIX6122 (£999). We have a lot of R1 DVDs. Can the DVD player be converted to multiregion?
  2. andi
    andi
    Bump. I would also like to know.
  3. DickieNibbles
    DickieNibbles
    Not 100% certain about the particular Loewe model you mention, but all the Loewe's I have come into contact with are Philips/Marantz based and as such are remote hackable. Suggest you ask a reputable/obliging Loewe dealer before purchasing.
    Be warned however, Loewe are particularly hot on this and should you need service under warranty, you may come unstuck!
    Hope this helps...
