hack code needed for philips DVP630
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by the_muff, May 31, 2004.
  1. the_muff
    the_muff
    Mar 25, 2003
    156
    edinburgh
    +3
    anyone know of a region hack code for the philips dvp630
    cheers.
  2. scoobyrestrepo
    scoobyrestrepo
    I’ve found the following works at making my Region 2 DVP630 region free:
    With player switched on and the disc tray open, type 7 8 9 OK 0 on the remote.
    The number 0 should appear briefly on the lower left side of the TV screen, where 0 represents ’region free’. If you want to make it a specific region, you would type the region number instead of 0 (so, to lock it on US region 1, type 7 8 9 OK 1, for example).
    Although it worked for me, I do not guarantee it will work for you, and you should region-free your machine at your own risk ;o)
