h57 Input Via VGA Not As Sharp As S-Video
Discussion in 'Projectors, Screens & Video Processors' started by Rick1486, Jul 27, 2005.
  1. Rick1486
    Rick1486
    Feb 22, 2003
    547
    16
    Oxfordshire
    Hi gang.
    Got my new Themescene H57 set up the other day and ran SKY+ via s-video. What an improvement over the old Sony HS10!
    Then I spoke with the rep. from Optoma who suggested I use the included Scart/RGB adaptor and a vga cable to input into the pj as he said it would be a better quality (basically almost component quality) picture.
    Now what I've noticed is that it does seem brighter as an image, but to me it also seems a bit blurred/ghosty (No. It is focused properly before you ask lol).
    Also we watched a box office film last night on Sky - "Birth" and the images looked a bit grainy to me - is this symptomatic of dlp's, was it just the film itself (as in parts of the film it was razor sharp), or is there an adjustment/setting issue somewhere here?
    I purchased a Lindy Premium Gold S-VGA cable (5mtr length) so it's not down to a crappy cable I wouldn't have thought, and I set SKY+ to output RGB not PAL.
    Any suggestions?
    Rick
  2. ZippyCat
    ZippyCat
    Aug 9, 2004
    572
    28
    +22
    To be honest the picture quality from Sky of late leaves a lot to be desired, and I would suggest that this is the cause of your problems. Far too many channels multiplexed into the same bandwidth, and its only going to get worse. Hopefully High Def will address some of these problems. I wont even use Sky on my projector anymore because of the poor bit rates etc.
  3. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    I have to agree with you Rick, I use S-video from my Sky+ to my lowly H30 and it also looks better than RGB over a VGA cable. Maybe it's to do with a better design to the output stage in the box?
    I find Sky+ via S-video very watchable on the majority of channels.
  4. Rick1486
    Rick1486
    Feb 22, 2003
    547
    16
    Oxfordshire
    I wish I'd known this mate before I just spent another £30 odd quid for a cable lol.
    Perhaps there's a techie here somewhere who can give us a workaround if there is one.
    Rick
  5. summat
    summat
    Dec 16, 2004
    90
    Preston
    To be honest, I think Zippycat's on the right track, here. The S-Video signal will suffer from a relatively low bandwidth - far, far worse than RGB / Component, and as such you're going to lose fidelity of the video signal - most likely seen as a smoothing of the picture. With a digital source with a lossy compression method (as with Sky) you're going to end up with digital artifacts - which is probably what you're seeing with the Scart cable, which the S-Video source blends into the background.
    Have you tried using a DVD as video source? - not perfect, but better than sky, to see if the Scart works "better" on that?, that'd answer the question as to whether the issue is to do with the cables or the video source.
    (One other possibility - mismatched impedances between PJ, cable, and Sky+, but that's unlikely)
    Mike
  6. Rick1486
    Rick1486
    Feb 22, 2003
    547
    16
    Oxfordshire
    Cheers boys - so Mike are you suggesting using the same rgb scart converter plugged into the scart on the dvd player using the same vga connection to compare the signal?
    Also, do you think it may make a difference if I plug the s-video cable back into the back of the Sky+?
    Rick
