H56, lovely!
Discussion in 'Projectors, Screens & Video Processors' started by Tonmeistermat, Aug 4, 2004.
  1. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Well my H56 arrived yesterday, and after much huming and hawing, and debates on these very forums, I can say that so far I'm a happy man!
    Am planning some serious movie watching over the coming weeks, but already I'm not looking out for technical stuff, and I'm enjoying watching the film... the trials and tribulations of deciding seem like an age ago, even though it was only last week!
    So I wanted to say thanks to everyone who's offered help and advice... The h56 may not be everyone's favourite projector, but it is mine, and I couldn't have made such an informed decision without you lot.
    Mat
  2. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    thinking about this one my self mate any pics at all?
  3. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Got a couple, but still in the camera. Will take some more, and try and up load them into this thread...
    Mat
  4. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    thanks mate that would be good
  5. stubie_do
    stubie_do
    Sep 8, 2002
    243
    Suffolk
    +33
    Hi Tonmeistermat,
    Sounds like you give the H56 a :smashin:.
    What other projector brands did you compare the H56 against as there are quite a few to choose from here in the UK and all a different price points?
    Let us know how you get on over the next couple of weeks as I'm quite sure other members would be interested to read your constuctive comments. :D
    I'm assuming you will be viewing with the 16:9 lens mask and without.
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,228
    UK.
    +2,764
    This pj compared very favourably with the NEC HT1000 when there was a shoot-out between them over on avsforum some months ago. For the money, it represents excellent value IMHO. IIRC, it was an Andrea Manuti driven shoot-out, and he's quite proffessional in his comments - he even uses Colorfacts to calibrate the projectors in order for them to show at their best. I believe the NEC had the edge, but when you consider the price difference now (back then it was more expensive), is the NEC worth the extra?
    I'd say yes obviously, because I have one, but the H56 wasn't available when I bought my HT1000 18months ago. :)
    Gary.
  7. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Hi guys,
    I checked a couple of other pjs... even though my limit was £1500 I looked at the sharp 200, and I also looked at the H30. The most detailed tests I did where between the 56 and the 30 (see the other thread). I took some close up pictures of the 30/56 stuff, and if they've come out I'll put them up!
    On the subject of the lense mask, I tried to put it on last night, and it seemed to do nothing but blur the top half of the 4:3 picture, and nothing at the bottom... Stuart, can you tell me how to use it properly?
    On a different note, I've got a high up shelf which the projector sits on, but of course it has to be upside down... can anyone tell me where I can get some bolts for the bottom ceiling mount system, as I'd like to make a small frame to hang the pj from rather than leave it resting on its top...
    Mat
  8. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Lets see if this works...
  9. stubie_do
    stubie_do
    Sep 8, 2002
    243
    Suffolk
    +33
    The lens mask is designed for when you are viewing a 16:9 source, it sounds to me that you are view a 4:3 image and then putting the 16:9 lens mask on?
    The idea behind the mask is to darken down the pixels at the top and bottom, commonly known as "overspill". By using the 16:9 mask you should see a slight improvement in black levels, from 2000:1 to around 2500:1 (IMHO).
    The angle of throw on the H56 was designed so that it throws the image slightly up when in desktop model (coffee table in the HC world). If you have mounted your H56 on a shelf high up, then no doubt the image was projecting high on the wall and possible just touching the ceiling. Your solution was to turn the projector upside-down on the shelf, right? I have seen this done in the past. I'm not sure what mount you are using, if its one of ours then you should have got the screws, unicol and/or LMP-PC are always updated as to our specs. Our angle of throw offset is to allow for approximately a 40cm black drop on the screen when the projector is ceiling mounted.
    Yes you could make a cradle to hold the projector or you could use a close couple mount (5/6 inch drop) on the underside of the shelf, this is done quite a lot.
    Hope this helps.
  10. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Hmmm you have to make them very small to fit on the website... I've put them on our web gallery much larger, which can be found at:
    http://81.6.236.223/gallery/view_album.php?set_albumName=homecinema
    These pics are two test pics on freeze frame when we had the 56 some weeks ago on test. It may seem rather odd that the image is above the sofa, but that's because we wanted to see the image framed by something so we could get a feel of the size...
  11. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Hi Stuart...
    You're right... I was using the lense mask with the pj set to 4:3. I assumed that it would filter off the top and bottom 'letterbox' black strips on a 1:1.85 picture displayed on 4:3. Your description makes things clearer.
    I've actually not got any kind of mount and was planning on trying to construct one... but the close couple mount sounds like it might answer my problem! Do Optoma do one, and if not can you recommend where I might be able to get hold of one for the H56?
    Ta!!!
  12. stubie_do
    stubie_do
    Sep 8, 2002
    243
    Suffolk
    +33
    No we don't do close couple mounts (yet). Try Andy at LMP-PC I think they advertise on the forums somewhere.
  13. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,228
    UK.
    +2,764
    How close do you need to get the pj to the ceiling? I've a couple of mounts on my home page that might work:
    http://www.g-lightfoot.pwp.blueyonder.co.uk/ht1000.html
    but I've also made one that will get the pj about an inch from the ceiling or less. I'll try to get the info on the site sometime soon, but here's a link to the pics on another part of the forum:
    http://www.avforums.com/frame.html?...hread.php?t=136884&page=1&pp=15&highlight=6mm
    If you can get the adjusting screws straight into the ceiling by using studs, then you can get the pj even closer. You can probably use some rawlbolts or similar for that. The rear holes are elongated to allow for sideways adjustment.
    Gary.
  14. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    THanks for the tips Gary, but I'm actually after making somthing that will sit on the shelf holding the projector straight. Our problem is that we have a sloping ceiling, so mounting on it is going to be very tricky, and it's not our place so I don't want to go bashing holes in the ceiling to find the joists.... I'm kinda after something like this....
    ---xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    ---xx------x----------------------x-------xx
    ---xx----xxxxxxxxxxxxxxxxxxxxxxxxxxxxx----xx
    ---xx-------------------------------------xx
    --xxx------------------------------------xxx
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    with the box in the middle being the upside down projector. It's just to stop it sitting upsidedown on its top, and to get it as square as possible! BTW this is a front view, looking into the lense...
    Mat
  15. gizzborn
    gizzborn
    Jan 8, 2004
    17
    nottingham
    I to have got a h56a and think it is a great projector . But can any body help it says in the manual about a signal menu but when i look it is not there.i am useing component cable to amp which is Yamahe dsp-750 se which is great help!!!. I to have mine on a shelf made a hole in the wall !!!!! got a under standing partner
  16. stubie_do
    stubie_do
    Sep 8, 2002
    243
    Suffolk
    +33
    I would have at a guess that you are running an interlaced signal. If you can run progressive then you will see the signal frequency adjustment menu.
  17. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    I think Stuart is on the correct lines. That option is only available with certain inputs I think...
  18. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    I've put up some pictures that compare the resolution of the H30 and the H56 on my website gallery....
    You should click on the thumnail and then on the image itself to see it full size. If you view them in the scaled down to fit in the gallery viewer it defeats the purpose! Unfortunately my camera ran out of battery before I could get an 'H56 close' to match the 'H30 close' image, but you can clearly see the difference on the overlayed close image.
    Will be putting some more up when I get a chance!
    Mat
  19. gizzborn
    gizzborn
    Jan 8, 2004
    17
    nottingham
    Thanks for that. so are you saying i need a new dvd player some think like pioneer dv-575a or the samsung hd 935 which as dvi d connection at the mo i have toshiba 220e!!!!!!!
    And wot about playstation and sky+ box how do you get the best picture at the mo they all go to amp and then to h56 .
    cheers
  20. Tonmeistermat
    Tonmeistermat
    Jan 10, 2003
    178
    Blackheath (UK)
    +3
    Watched Moulin Rouge last night as our first proper home cinema movie... Fabulous... Really enjoyed the movie, and am I'm now thinking about getting an image callibration DVD to fine tune it...
  21. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Avai (might still be available in the Powerbuy Forum ?) is an excellent aid to getting the best from your system................. was lucky enough to get mine as a pressie from a friend :smashin:
    Sean
