Quantcast
h56 help
M
Mike Antrum
I used to have an H56, and my dealer loaned me a lens mask. My dealer liked it, but I found that I got a bit of fringing near the edges of the picture, and to my eyes I didn't like it. I'm normally a bit of a sucker for gadgets, but I passed on this one.
Your dealer may lend you one, so ask him if you can try before you buy.
Regards,
Mike
gizzborn
Cheers Mike
you can't beat having gadgets!.is there any think else i should no about h56 as i have just got it like wot are the best setting you found or any think else and wot did you think of it.
cheers
Rich
