H3d!!!!!!!
buns
Well There is good new to everyone who is interested in one of these, I can now confirm that it is a top notch piece of kit and, in my opinion, worth every penny i spent. To put this further into perspective, I have only had a chance to comprehensively test the s-video input.
I would do a 'mini-review' but to be honest, I will wait until I have a chance to test at least the composite inputs as well.
Basically the thing which impresses me most is that, apart from updates, I havent had to touch the mouse or keyboard! I literally have to press play on my dvd player, the H3D card and software do the rest on their own for me. Wonderfully simple!
Im sure Couch Potato and Jenz will come around soon and give a bit of their thoughts!
So, if anyone has a spare $900 and was looking a capture card, this boyo is a very good line to investigate!
:D
ad
C
Couch Potato
Component in from a DVD player is better PQ than TheaterTek and the Svideo feed from Sky is very good, way better than my departing Pinnacle card. It uses Faroudja DCDi de-interlacing via the Fli2200 chipset. I'm now waiting for my SDI DVD player to check out the SDI input but am expecting high things. Just need to mend my Projector now :(
As far as ease of use, if your using it as a dedicated Video Processor it is exceptional. Once you've locked down your PC and hidden all icons and taskbar, it's definately got WAF. If you put Holo3D in the startup menu it fires up into fullscreen and all you have to do is select input type and source (from the included remote if required, oh and there's already a Pronto ccf avaialble!!) and you're away.
Cant wait for my DIGN case and with this in it I'll have a dedicated PC based Video Processor that looks stunning, both inside the rack and on the screen!!!
Highly recommended, if not exactly cheap. However it's a lot cheaper than the nearest black box equivalent :D
Edit, one of the EAP testers was Frank Doorhof of Cinematrix distribution fame, he regarded the SDI input as better than his (now retired) PSM-1, in his words, "It's my dream come true"!
Steve
Jeff
Its good not having to rely on the HTPC for DVD work isn't it, no more messing with dodgy sound card drivers etc. Just wait till you see SDI, its gorgeous. :D
J
Jenz
This is a sweet card.
Component Input from a DV27 is great. Even composite is not to bad for those old VHS tapes :D
S-Video is great also for GC...
Of course I now need component switching in my amp for Xbox and PS2 and Arcam :D
Anyone want an old IDS Falcon?
Jenz.
JohnAd
It is indeed a very nice card!
There still seem to be some issues with PAL and some digital receivers but those should be possible to solve.
Just thought I'd also point out that the daughtercard due out soon will also suppotr SCART style RGB which is very good news indeed.
Jenz, have you tried the latest DScaler with 72/75 yet?
John
C
Couch Potato
And previously using TheaterTek I had to stick with the Radeon 6025 drivers, I can now move to Catalyst!! There was definite improvement as well.
Only trouble, my DVd player packed in last week, SDI modded player in transit :D, yesterday, my PJ went pearshaped, I've now got to talk the wife into an 808:eek:
Steve
rhinoman
Excuse my ignorance chaps, but with the onboard dcdi processor, how much is ther to be gained by running an extra application like dscaler or do they work together. My second question is related to the answer of the 1st and that is if you no longer need to run dscaler because all the processing is hardware based, does that mean that you don't need much of a PC around the card, i.e. slow old processor just with a decent PSU perhaps.
C
Couch Potato
John,
The 3 options are:
1. 480i-->Fli2200/DCDi-->480P-->Holo-UI-->GPU/Scaling
2. 480i-->Fli2200/DCDi-->480P-->Dscaler-->GPU/Scaling
3. 480i-->Dscaler-->480P-->GPU/Scaling
So you get to try out which option gives you the best PQ for you.
Dscaler will allow you to use Judder Terminator at 72hz and 75hz.
I'm sure John Ad will pop in and give you a much better answer.
You do not have to run Dscaler, the Holo3D's been designed from the start to be Dscaler compatible, you get the best of both worlds!!
You could run a cut down PC, minimal H/D, no sound card low end processor and lower RAM however processor and RAM prices are so low now :rolleyes:, should operate at a relatively low temp though so the option for a very quiet HCPC maybe.
Steve
rhinoman
So the benefit of dscaler is to provide additional resolution outputs and refresh rates?
C
Couch Potato
No impact on resolution but allows the use of 72/75hz which is not available thro' Holo3D. There are some minor issues at the moment with H3D and PAL video sources where the Fli2200 isn't quite doing its stuff the way it could but no problems with DScaler.
John Ad: Help!!
One other point I'd like to make is the level of support is outstanding, speaking from personal experience of receiving a DOA card I had a replacement within 48 hours!
Steve
rhinoman
Ok, I think i get it, the card just takes the input and then passes it onto the graphics card for scaling, but if the graphic card is doing the scaling then whats the processor for?:confused:
Sorry for all the questions, I'll get it soon:rolleyes:
C
Couch Potato
De-interlacing, changing aspect ratio's, allowing video source switching!! It takes the interlaced signal does its magic and outputs the Progresive signal to the GPU
I'm sure if I'm getting this wrong somebody who's more knowledgeable will bale me out..... please bale me out :p
Steve
JohnAd
Steve
You're explainations sound good to me. THe FLI2200 takes 480i and converts to 480p (or 576i -> 576p) this is does very well indeed, the scaler in the graphics chip takes the 480p and scales it to whatever you device is running at.
What the software is doing here isn't much when using the fli2200, but it is important, the software must take the input and display it at the right times and in the right place, which is not as simple as it sounds. It must also control the hardware and set it up properly when you change inputs or formats.
On why you would use DScaler, well most people won't, CRT owners who want to get rid of 3:2 judder are the most liekly to make the switch. It can sometimes also be useful if you want to use the noise filters or the logo killer with annoying DOGS.
Joh
rhinoman
Thanks guys, think I've got it now.:)
C
Couch Potato
Oh and for those who know the name, the S/W developer for the Holo3D is Mark Rejhon, couldn't really be in safer hands :D
Steve
buns
Steve
To add, i think the word 'yet' is perhaps missing!
Ad
Rob.Screene
Although not a H3G owner, I would reall miss the CRT preserving Orbit feature on DScaler as it allows playstation type games on-screen without worry of tube-burn because of any bright stationary crosshair/text/score/health bar, etc as DScaler slowly moves the whole screen around.
regards,
Rob.
buns
regards,
Rob.
You can of course use descaler, i have the alpha installed and it works ok. I believe that there is a possibilty that descaler will become more a part of the h3d program. I certainly like the idea, but time will tell!
Ad
John DB
Rob,
I'm using my X-Box with D-Scaler via the H3D card to avoid burn-in. Works a treat although I'm only using bounce as I've never managed to get me head round the orbit feature :confused:
What are your ini settings?
Bounce=1
BouncePeriod=1800
DeferedOverlay=1
BounceTimerPeriod=1000
BounceAmplitude=25
Orbit=0
OrbitPeriodX=2700
OrbitPeriodY=3600
OrbitSize=8
OrbitTimerPeriod=60000
Here are some pics (stolen from AVS) of the UI of this excellent card:
Holo3dgraph montage
buns
burn in?
I just am using h3d for the most part, not descaler so cant help much. If you get really stuch im sure johnad will help!
ad
JohnAd
If I remember correctly (I didn't do all the aspect code) I think the oribit feature moves the picture around within a fixed blanking area. Orbiting should help with DOGS and fixed screen clutter and also works with stuff that fills the screen whereas bounce only works if there is blanking. To use orbiting you ned to have overscan > OrbitSize
John
JohnAd
I don't know all of Mark's plans for the H3d app but I do know they would be interested in getting DScaler's filters running on the stream. This should be possible but will take a while.
John
JohnAd
Originally posted by Bert Coules
This sounds intriguing. Do I read your post aright? This is a feature of Descaler?
What exactly is the visual effect?
[/B]
Bert
The feature is new and changing frequently but basically you blur the background over the logo. At the moment this can look obvious and is slightly distracting, but often is a lot less distracting than the logo.
I've used it in anger at the BBC Choice logo and it works quite well, on the old 5 logo it worked OK but that is a bigger and less obtrusive logo anyway.
John
Bert Coules
John,
Thanks for the explanation. Is this something you have to adjust every time for each individual channel, or can the settings be stored and recalled?
I don't understand why some enterprising manufacturer hasn't marketed a small black box which generates an adjustable blanking signal, either to blur the logos or eradicate them in some other way. Wouldn't that be a best-seller?
Bert
www.bertcoules.co.uk
Latest News
LG rumoured to release 97-inch OLED TV in 2022
  • By Andy Bassett
  • Published
What's new on Blu-ray (UK) for Halloween 2021
  • By Mark Costello
  • Published
AVForums Movies Podcast: 20th October 2021
  • By Phil Hinton
  • Published
PSB announces M4U 8 MKII wireless headphone
  • By Andy Bassett
  • Published
Melco introduces N50-S38 music library
  • By Andy Bassett
  • Published
