H31/H30a jammed on me
Discussion in 'Projectors, Screens & Video Processors' started by IVOLIC, Aug 20, 2005.
  1. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    Hi all, :hiya:
    I have the H31 for about a month now and LOVE it. :clap:
    Anyway, I was playing with the settings, as usual, and while changing from 4:3 to 16:9 using the remote it JAMMED :eek: I tried pressing every button available but nothing could remove the menu from the screen.
    At first I thought that my remote lost the connection with the unit. Then I tried using the buttons on the PJ itself. I then decided to turn off the DVD hoping that the signal loose would reset the PJ in some way. Nothing, nothing, NOTHING. I then tried to turn off the PJ. NOTHING!!!!
    I had no choice but to unplug :mad: the pj from it's socket!!!!
    I quickly plugged it back in and turned it on so it could cool down using it's fan.
    After the PJ could down and the waning lamp for the bulb turned off I waited about a half and hour before turing it back on. Happy to say that everything was back to normal but I am wondering how much damage I have done to my bulb in the long term. :rolleyes:
    Just wanted to let people know.
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    IVOLIC,
    The joys of software controlled devices. It's a fact of life that a lot of them lock up from time to time.
    I would not be too concerned about what happened.
    I have had the odd projector lock up over the years and had to pull the plug and it has done no harm to the projector and I doubt the lamp has come to any harm as it cools down slower.
    Jeff
