H30 and Sky Digital..solution found?
Discussion in 'Projectors, Screens & Video Processors' started by FlyingBig, Sep 22, 2004.
  1. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    Problematic from the get go. Sound is out of sync and basically renders sky digital unusable with this great little projector. For what its worth Xbox sound is also slightly out of sync. I am using the vga to scart adapter with a coupler so i can connect a male scart, is this the problem is it just a fundamental problem with projector technology? Thanks for any help in advance.
  2. bobbetts
    bobbetts
    Dec 13, 2002
    154
    Norfolk
    I too have this issue, I believe it is something to do with the video processing required in the projector, this causes a small delay, thus sound and picture are out of sync.
    I am not an expert on such matters, so someone please feel free to correct me.
  3. trainspotter
    trainspotter
    Dec 14, 2003
    148
    I am having the same problem, (my set up sky+, HS30 vga via scart) however it does vary between channels. I was under the impression that it was sky that had the problem, and the fact that i had a 28inch screen previously, I simply had not noticed it, as It was not so obvious.
