Most unlikelyIs it possible to burn a h264.mkv program on to a standard DVD to play on a Blu-ray player?
If not what would you do to the file to make it dvd or better quality to play on the Blu-ray?
I mean without reformating it or getting rid of the High Def?
Any Blu-ray player should easily be able to play MPEG4-AVC files, DivX7 also supports H264.MKV-files, hopefully that will speed up better support for more than the oldest DivX-files as it is today.
Until then have a look at MPEG-4 Encoder GUIs - Doom9's Forum for Guides and GUIs.
Correct, I use TsMuxer to create Blu-ray structure (AVCHD ?) from .mkv files (usually 720p) and use Nero to write to DVD+RW disk in UDF2.5 format.What you link to is the same as what TsMuxer does. In fact some of those program uses TsMuxer in the background to create the blu ray structure. The player still needs to have the AVCHD logo somewhere.
MKV files can certainly be made into AVCHD if the video is H264 and the audio is AC3.
