H(T/C)-PC and Denon 3803
Discussion in 'Desktop & Laptop Computers Forum' started by slyborg, Sep 18, 2003.
  1. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Quick question, I love the video/audio source management that I get with my new 3803 as I used to have to swap plugs about. My question is if I go the PC route would I be better inputting Sky and X-Box to the PC and not routing any video through the 3803? I just wondering because the switching from one source to another at the moment is simplicity itself and I don't really want to lose that if I can help it.
    Oh one other question now I think about it, currently I use optical for the Sky+ and X-Box, what would I need to get both sources into the PC or would I have to use alternative wiring/plugs?
    Si
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    I currently route all video through my 3802, and then feed the HTPC with the "monitor" video output on the amp.
    Why do you want to pump the audio into the HTPC? PVR?
  3. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Oddly enough it ocurred to me about half an hour ago that I don't need to bother routing the audio :)
    Should help with my HCPC requirements as I can just go for a standard sound card for playback of MP3s etc. and I won't need a plethora of inputs for video :)
    Think it's about time I fully spec myself out with an HCPC!!
    Si
    PS: Mind if I ask what sorta spec your HCPC is? Are you outputting to a plasma? As I'll be looking at outputting to a Panny 42"
    PPS: I'm an idot for not looking at your sig *sigh* been a long day!!
  4. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    No problem. In case you were wondering what a NEC DP1200 is, it's an old 3 CRT projector. Pretty uncommon over here.
    Sean
