H/K Soundsticks II - Any better-same price?
Discussion in 'Computer Components' started by AndySimmons, Sep 22, 2007.
  1. AndySimmons
    AndySimmons
    I want to buy some speakers for my computer. Not surround! i wondered if there exist any better speakers for the same price range?
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    i am listening to my sticks right now, they are just superb, I love them to bits, the sound is great and they look the part, for me, i have to say unless you spend considerably more, you will not get better.
  3. AndySimmons
    AndySimmons
    Thanks, I'm sure I'll be happy with them anyway :)
  4. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    Acoustic Energy Aego M 2.1 are supposed to be the best PC speakers available.
  5. AndySimmons
    AndySimmons
    I'll probably go for those. Thanks a lot. Seems very good. Design, no. Sound, yes. And sound is most important to me in this case... I'm a fan of music
  6. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    for me the looks were a bonus, the sound was the big issue for me, they are just crisp and tight sounding, you will regret it if you don't get them.:thumbsup:
  7. AndySimmons
    AndySimmons
    I'm goind for sound :)
  8. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    I'd go for sound quality over looks as well.
  9. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    I also went for sound, i think you need to get them side by side and audition both.
  10. AndySimmons
    AndySimmons
    I agree. I just hope that Acoustic Energy Aego M Is better... It cost a lot more
  11. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    Well if you want the best sound quality, you should go down seperates, it'll cost around 4x as much as the Aego's though. Also has input switching, so if you have lots of sources (rather than just one, the PC) they're worthwhile.
  12. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    well as he wants to spend what the soundsticks cost, it is unlikeley something costing 4X te aego`s will fit in the equation :lesson: extra maths this week for badbob:eek: :hiya:
  13. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    Yeah I'm just saying if he has 2+ sources, then needs to go seperates. He didn't say can't increase the budget either.
  14. AndySimmons
    AndySimmons
    That's right. I can't pay 4x, though I could... I can afford it, but I'm spending money like never before on computer, games, mp3-players, lcd-screen etc.
    I'll go for the Aego. Looks like ****, but it has a timeless design right? :p
  15. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    saving £20 and they do look nice, if i was in the market for some new speakers they would definitely be on my hot list, whichever you go for and end up with ENJOY.
    Regards Ian
  16. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    If you want decent 2 channel pc sound, get an old power amp (doesn't need to have fancy features, just a power amp, I'd use a Quad 303) and a pair of bookshelf monitor speakers - pretty much any secondhand 2 channel stereo system you could knock up in this way will sound better than the soundsticks for similar price - having said that I have a set of Soundsticks on my bedroom / desktop system
