H/K AVR 7500 sound problem!
Discussion in 'AV Receivers & Amplifiers' started by wolfpack, Feb 5, 2005.
  1. wolfpack
    wolfpack
    Hello!
    I have a very annoying problem with my amp. It increases the sound level by it self (the level varies anywhere between 1-30db) in sudden bursts. A little while after i adjust it, it does it again. I've checked the batteries and they are ok. I can't use it until i fix this so if anyone has any suggestions what the problem may be, I would be most grateful.
    Robert
  2. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    You don't have a remote transmitter to control the amp/satellite from another room or anything like that nearby do you?
  3. wolfpack
    wolfpack
    Only the IR-reciever for my htpc but i've checked the remote on that too.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    are you using a plasma or other device with high IR radiation?
  5. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    We had a similar problem with an HK 630, the volume would shoot up and down for no reason. It turned out to be the remote transmitter that is used to control the satellite box from another room. As soon as we unplugged this, the problem went away.
  6. wolfpack
    wolfpack
    I installed my plasma last thursday!
  7. wolfpack
    wolfpack
    Weird, i removed the remote from the room and then everything worked (the batteries are fresh and working). Can it be the remote itself that's broken somehow?
  8. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    Could be the remote emitting a signal when it shouldn't. Something inside stuck down maybe.
