h/k 7500/8500 replacement at AVland
russraff
I think that AV land have the replacement for the 7500/8500 on their site here. I suspect that it is the 7500, as the amp (AVR1030) doesn't have an i-link connection and isn't THX certified.
What do you think?
Russell
Dfour
Looks like it will be a killer amp. If I had the moeny I would buy one :D
Andywilliams
Hi russ
It is thx ultra 2 certified.
Cheers Gonzo.:)
russraff
What's this then! :confused:
Ahh, I was looking at the photo and couldn't see the THX badge. Perhaps the photo is the 7500 replacement and the description is the 1030?
Russell
Triggaaar
I tested the HK8500 last year, and thought it had the best stereo performance in its class. But a lack of time delay, for combatting lip-sync probs when using de-interlacers and plasmas, put me off. Does this replacement have a time delay (didn't see it in the spec link above)?
PC Nut
Bluesfan: where do you get this info.............
bluesfan
Coaxial reply to me.
Trader Rating: (0)
Saw the HK 630 in action at the Manchester Hifi show, it was jumping between DTS formats on their DTS demo disk no problem, much quicker than my Rotel. Still about 1/2 a second tho, if ur being fussy. I think the recent pioneers are quicker, but I still don't rate them as high as HK kit on the sound quality front..
Tip:Try rgbdirect for hk.
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
