H & B High Quality HDTV 32
Discussion in 'LCD & LED LCD TVs Forum' started by rmg, Jun 23, 2005.
Tags:
  1. rmg
    rmg
    any thoughts on this TV, it looks good and positive reviews.
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=86835
    Features
    Flatscreen LCD TV
    Screen size: 32" / 81cm (diagonal)
    Resolution: WXGA, 1366 x 768 pixels
    Format: 16:9
    Brightness: 550 cd/m²
    Contrast Ratio: 600:1
    Colors: 16.7 Million
    Viewing angle >160°
    Dolby Digital 3-D Effect speakers
    PAL/NTSC Video Compatible
    Compatible resolutions: 1080i, 720p, 480i/p
    Power supply : 110~240V AC vPanel switches : Power / Select (menu) / up / down
    Multilingual OSD
    TV Text
    Display functions: Zoom, Freeze, PIP, PBP vAudio output 2X7W, Surround Sound (WOW)
    Video input : RCA Composite (1 X IN / 1 X OUT), (2) SCART (1 X RGB) (2) Component YPbPr, (1) S-Video Mini DIN 4-pin
    PC input : VGA (Sub D-15) , DVI input: DVI (HDCP)
    Audio System: (5) RCA (L/R),
    Double PLL TV Tuner PAL/SECAM (BG/I/DK/L)
    RF TV input
    Nicam stereo compatible
    Seems to be missing HDMI and no 1080P but for £930 inc VAT....
  2. Italights
    Italights
    Think it might be the same set as the Relisys rlt3200
  3. DanH
    DanH
    Feb 16, 2005
    604
    +56
  4. Spoonboy90
    Spoonboy90
    May 19, 2005
    692
    Stoke-on-Trent
    +62
