H and V Sync
Discussion in 'Projectors, Screens & Video Processors' started by Orbital, Oct 25, 2001.
  1. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Hi All,
    I've just received my cable to connect my HTPC to my BD800 (HD15 to 5 BNC’s) Now even I can figure out which BNC goes to the red, green and blue sockets, but with the black and yellow ones I don't know which is the horizontal and which is the vertical sync. Could someone please put me out of my misery?
    Dave
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Dave
    Normally black is Horizontal or Composite and Yellow is Vertical but not always. It seems to be differnt in each country.
    You will do no harm is swapping them over. Give the projector 5 seconds to lock onto the signal befor you start swapping again.
    Don't forget your 800 projector must have negative syncs from the PC.
    Some of the PC resolutions force to +ve
    800x600 for instance.
    You need something like powerstrip to get into your graphics card sync settings
