Gyrodec sound problem
Discussion in 'Hi-Fi Stereo Systems & Separates' started by gazza73, Apr 29, 2007.
  1. gazza73
    gazza73
    Oct 28, 2006
    139
    +8
    At the moment my system via CD sounds fantastic but the vinyl end sounds a little bass light, lacking definition while the treble has gone beyond detailed and is sounding very bright. I have tweaked the TT's tracking force and VTA etc and feel I've gone as far as I can go. I am not a big believer in cables making massive changes to the sound so I can only think either the cartridge is a little worn or just not the right one for my system.
    My system is as follows:
    Gyrodec SE
    Tecnoarm
    Ortofon 540 mkII MM cartridge
    HR Power Supply
    Trichord Dino/Dino +
    Exposure 23 pre/28 power
    Linn Karik II
    PMC OB1
    Black Rohidium Symphony interconnects
    QED XT-400 speaker cable
    Do you guys have any reccommendations for the above problems.
  2. Beobloke
    Beobloke
    Aug 10, 2004
    1,315
    Out in the Sticks!
    +67
    The TecnoArm tends to have a bright sound as a result of its silver wiring, and the 540 is a bit of a dog-eared thing, so this could well be giving your problem.
    Personally I'd change the cartridge for an MC - Don't know how rich you are ;) , but £300 or so on something like an Audio Technica AT-OC9II or Ortofon Rondo Red should help.
  3. DOBLY
    DOBLY
    Oct 30, 2006
    1,742
    116
    Dunedin
    +659
    I have had great results from a Sumiko Blue Point Special - although I do not have the Technoarm for my Gyro SE, and have very different amplification, cabling and speakers to you. I am thinking of upgrading to the Sumiko Blackbird, which is quite a bit more money, but promises an even better soundstage.
    Hope this is of some help to you.
    Cheers,
    Dobly
