Gyrodec SE, skipping across vinyl
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Woodsman, Jan 6, 2012.
  1. Woodsman
    Woodsman
    Dec 27, 2011
    22
    4
    Hi Guys, longer time lurker and all that.....i have a problem that thread title sums up fairly well. When i place the tone arm of my Gyrodeck down to play it skips across the surface of the vinyl! i've tried with my limited knowlede of adusting the tonearm (Rega RB-300) to no effect. Has anyone else had this problem and know of any fixes? Cheers.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,229
    2
    +3,718
    Sounds like the anti-skate and possible the counterweight are out of sync.
    Couple of follow up questions;
    What cartridge is on the arm?
    Will it hold a groove at all, or does it make straight for the centre?
    Have you changed anything recently?
  3. Woodsman
    Woodsman
    Dec 27, 2011
    22
    4
    Hi Ed, Its a some what unloved Ortofon MC 15 super ii...
    It skips lighly across the surface, bouncing almost, straight towards the center.
    Well we did have a New Years Eve party not long ago.......
  4. Ambo
    Ambo
    Aug 2, 2005
    438
    Essex
    +62
  5. formbypc
    formbypc
    Oct 9, 2010
    1,579
    63
    +104
    Check the stylus is still in place.
    With a high-power magnifier, check the stylus still has a tip on it, or -
    Without switching on the turntable, place the tonearm on a record and move the record by hand. With the exception of the speed being incorrect, does it sound 'normal'? If it does, that suggests stylus and tip are still OK.
    Tell us what you did to adjust the tracking weight and anti-skate.
    In short, you should get the arm balanced so that it's level, by moving the weight on the rear of the arm. Then, without moving the weight, move the weight indicator on the front of the tracking weight to zero, then move the weight and indicator together till the indicator shows the desired weight. Then set the antiskate to correspond.
  6. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,229
    2
    +3,718
    In extremis, if the cartridge looks fine and it still does this after the arm is balanced, it is possible that the spring mechanism in the anti skate has failed.
  7. Woodsman
    Woodsman
    Dec 27, 2011
    22
    4
    The tone arm is a Rega 300. When i get home this evening i'll take a proper look at the set up (and stylus), prior to dropping it into Music Matters. I'll let you know how i get on. Cheers.
  8. Ambo
    Ambo
    Aug 2, 2005
    438
    Essex
    +62
    Here's the RB300 instruction manual:
  9. Woodsman
    Woodsman
    Dec 27, 2011
    22
    4
    Well it's taken a while to sit down and take a proper look....fairly straight forward problem in the end, the stylus had come off!
    Just need a replacement now. Any suggestions?
  10. formbypc
    formbypc
    Oct 9, 2010
    1,579
    63
    +104
    How much do you want to spend?
  11. Woodsman
    Woodsman
    Dec 27, 2011
    22
    4
    As little as possible to be honest. Would £250 get me anything worth while? Prefer to spend less if possible......
  12. rorackowe
    rorackowe
    Sep 27, 2007
    1,887
    63
    +207
    Mm or mc? Goldring 1042 / reason reca is ok on my Gyro.
