gyration ultra causing boot up problems
Discussion in 'Desktop & Laptop Computers Forum' started by gslater, Jun 22, 2005.
  1. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    I have purchased a gyration ultra keyboard and mouse to work with my htpc. When I plug the receiver into the usb port and boot up the pc, it gets throiugh the bios routine but then hangs for a considerable period of time before booting up into windows. What could be causing this?
    I thought it may be a matter of looking in the bios to enable a usb (rather than ps2) input device but I cannot see any such setting...I am running the following:
    MSI K8N Neo4 mobo
    Athlon 64 300+
    Once it finally boots into windows ity is recognising the mouse but only selective keys are working on the keyboard (althogh this may be a battery problem as I read elshwhere that the gyration ships with cheap chinese batteries which may only work for a short while)
    Any thoughts?
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    does removing the gyration completely allow you to boot up normally?
    when the keyboard works selectively is it always the same keys that fail or different ones at different times? I had a problem with my keyboard not working 100% but solved it just by repositioning the antenna, suppose it must have been picking up some interference or something.
  3. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    when I put in my regular ps2 keyboard & mouyse it boots up just fine, its only when I put in the gyration that I have the problem.
    it does seem to be the same keys not working...but I am not 100% sure of this yet.
  4. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    that seems quite strange. do you have another PC which you can try the gyration with?
  5. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    good point...will give this a whirl.
