GXFX Speaker stands please help.
Discussion in 'Home Cinema Speakers' started by canada16, Mar 4, 2013.
  1. canada16
    canada16
    Nov 15, 2009
    1,052
    Cardiff
    +45
    Hey
    I have moved into a flat and its all plasterboard and studs.
    The owner said she doesnt mint me putting up shelves, but I dont trust plasterboard screws to hold the weight of the GXFX.
    Has anyone got these on some stands that may compliment my speakers.
    I would need to put one behind a sofa so they would need to be fairly skinny on the poles.
    Thanks so much
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,437
    Could you not find the studs and then attach the speakers to these?
    There are also options for fixing to plasterboard with metal fittings that spread the load.
  3. Darkmatter21
    Darkmatter21
    Nov 24, 2010
    1,394
    48
    Rugby
    +80
    How much do they weigh? I have my RX FX in a plasterboard stud wall without putting them into the studs and they seem perfectly safe.
  4. meduk1
    meduk1
    Jun 17, 2009
    538
    28
    UK
    +46
    I had RXFX on a plasterboard wall using the weight spreading bolts that have been mentioned and they were fine. The specs of the bolds I had could hold an awefull lot!
  5. Madskilzz
    Madskilzz
    Mar 16, 2002
    348
    Harrow
    +73
    Tipping the scale at almost 12kg the GXFX are almost three times the weight of the RXFX.
  6. canada16
    canada16
    Nov 15, 2009
    1,052
    Cardiff
    +45
    Anyone help?
    I know they cannot go on the wall and really missing them, as only have the front 3 up.
    Thanks again
  7. meduk1
    meduk1
    Jun 17, 2009
    538
    28
    UK
    +46
