Guys with a PW6 or 7 hooked upto a HTPC, what res do you have it on?
Discussion in 'Plasma TVs' started by Alexg, Mar 14, 2005.
  1. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    As topic,
    What do you have the resolution of your PC set on when using it with these plasma?
    Many thanks
  2. Rob100
    Rob100
    Nov 3, 2002
    3,468
    +227
    I have a 42PW5 - this is the same native res as the 6 and 7 series SD 42" displays, that being 852x480.
    I use both 848x480 and 856x480 from my HTPC.
    Rob.
  3. Andrew_P_S
    Andrew_P_S
    I have a 50PHD7 and use a FREE download called POWERSTRIP to match the 1366 x 768 resolution.
    This resolution is already in the program as a pre-defined setting, but you can customise any resolution. Also lets you play with refresh rates etc.
  4. lisag
    lisag
    Jul 14, 2004
    5,558
    Essex
    +297
    See the thread 'using a pc as a scaler' if you want to learn about 1:1 pixel mapping..... or, just use a resolution that looks nice to you!
    lisa
  5. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    But the minimum I can set the pc on is 800x600...?
  6. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
    Do a google search on "Powerstrip" this is a piece of sofwtare that will let you send a custom resolution to get the best from the screen using a PC.
    Rob100 suggests some good powerstrip settings that I have used on my friends PW6 with good results...
    JJ
