guys i have made a mistake whilst building my HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by cowtipper, Jul 13, 2004.
  1. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    What a pratt is all i can say i bought a pc from ebay cheap but and i did not realise until it arrived it has only got 2 pci and an AGP slot as it is a micro atx which is good as the foot print attracted me to the pc in the 1st place (WAF kicked in on that decision) :)
    so here comes the problem
    I have a 256mb 9600 vga agp card
    a sweetspot pci card
    a realmagic pci xcard
    a i was going to add a M-audio pci card but i have run out of slots and the MOBO does nto havea n spdiff out
    so the dilemma is do i scrap the xcard in favour of a pci M-audio card or do i buy an extigy USB sound card or do i just sell the pc and get another box with 3 pci slots which will have a bigger footprint (taking into account the WAF please)
    again what a prat how could i of over looked such a simple thing :oops:
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    remember that your xcard has digital audio output on it, so do you really need an additional sound card?
  3. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    i did notice that but thought it would only be for the dvd itself not the whole system
    i am obviously new to this HTPC world and i am still feeling my feet
    so will it service the whole of the pc for audio and if so what is the sound quality like
  4. Kramer
    Kramer
    It will just allow SPDIF for DVDs AFAIK, not general Windows sound - WMP etc.
    :smoke:
  5. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    You could drop the Xcard and buy a software DVD player to make room for the PCI sound card?
  6. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    i didi thik of that but i really wanted to pipe the DVD through the xcard then the sweetspot card so i could use descaler
    david pluggedin any comments about the Spdif
  7. Alex Simon
    Alex Simon
    Well if your mobo has an internal SPDIF (maybe not if it doesn't have external) then you can loop it back into Xcard and only have one output for everything.
    Another option would be to try Joveplayer this *might* send other media through xcard's SPDIF. Of course this would only work when used as a media-player - games, office apps, etc probably wouldn't output this way.
    Other than that, something will have to give.
    A software DVD player is one way to go.
    Or, if you are intent on using DScaler, you could use an external DVD player connected via component.
    Penultimate option is to replace both Xcard and SweetSpot with an external SDI dvd player and SweetSpot SDI capture card.
    Last option is to replace your mobo for a similar one with SPDIF out - probably the cheapest option.
  8. csayers
    csayers
    Mar 13, 2002
    39
    9
    London, UK
  9. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    damn so we have now established that xcard spdif on the xcard only outputs from the dvd player
    the reason for the xcard was so i could scrap my standalone sony 735 dvd player and just use the pc as everyone i have spoken to said that a pc based dvd solution will blow the socks of any standalone dvd
    so my next quesiton then has anyone tryed to use the creative audigy NX usb they are only £80 and i have read a few reviews and they look good
    or does anyone have a any other ideas ?
  10. MikeTV
    MikeTV
    Feb 1, 2003
    7,782
    Ealing, London
    +842
    What kind of display are you planning on using?
    Assuming it's a radeon graphics card, you may be able to connect the display directly to the vga output on the card, and then there is no real need for the xcard at all (you can just play DVD's directly via a software player, and the results will be comparable to the XCard/DScaler approach). But it depends on the display type - PAL/NTSC/HDTV/VGA?
    (and then use the spare slot for an m-audio card)
  11. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    ok so iam losing my sense a bit now i was told that an xcard will give far greater PQ then a software based solution as i can run it through descaler and output a progrressive signal which a software player would not give me
    I am using a ati radeon card with an YUV dongle to a plasma and i cant use VGA as its a viera and the VGA port is on the front i have thought about modifying a vga cable to get a vga feed to the rear of the screen so you cant see the cable and cut out the onboard scaler hmm may have a think about that more today see what i can knock up
  12. SimonInd
    SimonInd
    May 9, 2001
    209
    London
    I would have thought a Radeon supplying 1:1 pixel mapped VGA to your plasma will 'blow the socks off' any other approach. The only reason I moved to a PC was get get 1:1 mapping on my projector. A good software DVD player will provide you with an excellent picture if you take this approach.
    Simon
  13. Alex Simon
    Alex Simon
    With film-based material, Xcard and the best software players (TheaterTek for example) will be broadly similar in quality.
    However, with video content (tv series, some manga, dvd extras, etc) Xcard/DScaler can offer a much more consistent picture.
    Either way, you are still scaling using the Radeon. It's the deinterlacing that's done differently.
    Xcard could also drive another discplay using it's other analogue outputs.
    Hope that helps
    Alex
  14. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    guys i do really appreciate all the help
    i have decided the xcard stays for now i have got a small cheapo usb to optical converter i am going to use for audio for now then i will compare software dased dvd playback compared to the xcard and see which gives the best PQ and if the xcard wins then i am going to purchase either audigy 2 nx or the m audio usb soundcard odviously if the software based version wins then there will be an xcard going cheap
  15. denniswaugh
    denniswaugh
    Nov 13, 2003
    222
    Northampton
    +4
  16. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    tnx for that i could not see what format the board is as i need a micro atx
    and i have the AMD barton care 3000xp
    I am still kicking myself for this one i am officially a pratt
  17. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    ok so my head is spinning once again i have found another post that reccomends a software based dvd solution over the xcard damn HCPC i wish i had never found www.avforums.com it costs me too much money and too much stress
  18. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    guys sorted it out the pc is going back i am not happy doing it half hearted so i am goign to purchase a system with at least 3 pci slots
    and purchase the m audio audiphile
    then i will run optical to my amp for mp3 and use the xcards coax to my amp for dvds that way when i hit the dvd button on the remote it will have it own audio line in
