I've not done any work on gutters before. I've got a gutter that runs on the outside of the kitchen which is a single story outhouse behind a Victorian terrace. It must date from when it was converted to a kitchen and all fittings are plastic. The existing gutter doesn't cope if it's anything other than light rain, so I plan to fit an additional downpipe which can go straight into a drain. My question is around the T piece outlet which I need to fit into the existing gutter - I will have to cut the existing gutter and leave a gap. I can't work out what make the gutter is, it seems to be around the standard 113mm size, but how much do these vary and will a good squirt of silicone make up any difference?
Any other advice? The rest of the work should be fitting the new downpipe and securing it to the wall with U clips.
Chris
Chris
