GUIDE Plus+ on NTL?
Discussion in 'Cable TV & Virgin Media TV' started by bonefish, Sep 10, 2003.
  1. bonefish
    bonefish
    Does anyone know if the 'GUIDE Plus+' programme scheduler that comes with the Philips DVDR80 etc. works on UK NTL cable? As I am sick of buying features that don't work in the UK.
    Appreciate your views.
    Bonefish
  2. auto
    auto
    I have just bought a Philips with Guide Plus+ and i am
    waiting for it to be delivered, I am also UK NTL.
    Anyway I was looking through the internet and
    found this site which gives info on Philips DVDR80 and guide Plus+.
    Here it is : http://www.redremote.co.uk/dvdr80.html
    Hope this can help you out.
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Yep extremly annoying i have a DVDR80 and couldn't use guide plus beacuse of the way cable boxes use ir. Most of the boxes use a non standard IR signal which is incompatable with the philips system (uses something simialr to the pc data transfer ir system).
    I believe there maybe one box out there that actauly uses a proper ir signal and thus work but this will probably have other flaws. You can get that redeye thing which converts but it is another £30 or so.
  4. philws
    philws
    I've been using GUIDE Plus+ on analogue NTL for over a year without problem. However, this only gives the schedule for the terrestrial channels.
    I've been considering upgrading to digital but want to ensure I won't lose GUIDE Plus+ (coz it's just so handy and easy to use)... if anyone knows if it works on digital I'd love to hear...
    Phil :n.
  5. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    RE run through the setup and select a digital set top box, this should give you all the channels that box can receive (at least in theory).
  6. philws
    philws
    Do you know if you have to have EUROSport as a subscribed channel in order to get the GUIDE Plus+ schedule?
