Guide on the Viera
Discussion in 'Plasma TVs' started by GazTheHat, Jan 19, 2005.
  1. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    Hi all,
    Is it me, or does the guide on the Viera only have a listing of what is on "now and "next" ?? It only ever shows these two progs. Just wandered if there's a way to show the programmes for the whole day, or rest of it?? That would make it useful. Browsed manual but nothing.
  2. davegtt
    davegtt
    Dec 22, 2004
    112
    actually press the "guide" button, that should bring up TV listings for the whole week.....
  3. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    Really!?! :laugh:
    Yes, i know that, but on "today" it only shows now & next, not the whole days listings.
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Would this be fixed by an update to the DVB tuner firmware?
    S.
  5. davegtt
    davegtt
    Dec 22, 2004
    112
    Only trying to help :rolleyes:
    well theres something wrong. I get the next 4-6 hours and more if you scroll down IIRC
  6. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    How is this done? I tried the update from the menu, and it said no updates were available, that it was up-to-date.
    I checked the guide again last night. And it only ever shows just now and next for the current day. After davegtt's comments, i checked out the 7 day guide. Nothing shows for any of the channels on any of the days. Something like "No event available". So basically, the guide is a now/next service on my tv.
    Anyone have a similar experience, or is mine shafted/need tweaking? :confused:
    It's only a standard aerial i'm using, no sky/cable/etc....
  7. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Your EPG needs an update.
    They are available here:
    http://www.dtg.org.uk/retailer/download_schedule.pl
    You have to keep checking as they only broadcast Panasonic every now and then.
    You need the viera to power on to BBC1 in DVB.Then follow the instructions.
    From memory the new software is version 36.
    The above all worked for me.
  8. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    Thanks a lot Happy!! :thumbsup: :thumbsup:
    I thought there had to be a reason, cus the now/next alone in the guide is a waste of time. I'll lOOk into this now and be back if there's probs.
  9. buzzby
    buzzby
    i have the same prob so thx for the thread
  10. buzzby
    buzzby
    ahh just looked they are updating next week between the 2nd and 3rd
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    02/02/05
    03/02/05
    Panasonic
    Th-37/42PE30B, Th-50PV30B & TX-26/32LXD1
    v2.36
    Repeat
  12. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    Fantastic, next week. To those that have updated previously, do you notice anything happening? Are there messages? Do you know when it's complete? On/Off after update?
    Just out of impatient curiosity... :rolleyes:
  13. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    You must power up straight to BBC1 in DVB mode. Then you get the message that new services have been found. Follow the instructions.Takes about 5 mins.Then says it's finished.
    You then get a full 7 day EPG
  14. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    Super, can't wait to play. :thumbsup: Thanks for the info all.
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    make sure you leave it in standby over night on a BBC DVB channel
  16. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    ?? :confused: ??
    Sorry, you got me there HD. Standby overnight? You mean turn it off (from remote), when viewing BBC1 in DVB?
    I always do that anyway, i never power down from the button on the set or mains. Should i be?? Never thought otherwise TBH.
  17. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Yeh, confused me too.
    I know from experience that power off, power on (from remote) works so long as the set goes straight to dvb bbc1
  18. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    Cool, thanks for confirming that Happy.
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    sorry been busy MEga Plasma test and all.... dont switch it off after watchong ITV3 on the days of update, switch to a BBC channel before hitting standby (and dont power off at mains or front panel) make sure you are on DVB not analogue
  20. pablo99
    pablo99
    Oct 15, 2004
    383
    Aberdeen
    +16
    I'm gonna need to do this next week also.
    My current version is V2.26 and I have the "Now and Next" problem. Can I confirm I can also ask the telly to check for upgrades from the DVB Setup Menu? I plan to do this Wed night.
  21. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Yes do that , then next week when the update is being broadcast follow my earlier instructions about power up to BB1 in DVB etc.
