guessing that this doesn't exsist
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by simonoaks, Feb 2, 2009.
  1. simonoaks
    simonoaks
    Apr 8, 2007
    1,821
    48
    Dunstable
    +72
    Have a very odd need; a cabinet that can hold a 46-50 inch plasma, an amp, sky box and blu-ray.....however, also want it to be able to hold 2 speakers in a 2.0 set-up. Speakers will be bookshelf mid range so up to hxwxd 380mmx280mmx280 roughly.
    Or, a proper corner stand (ones I can find not big enough), as I was thinking of putting it corner with screen stand straddling across the apex righ-angle then putting bookshelfs at eather end on each side of tv,
    any suggestions.
    If I have to get one made, are they very expensive if I go for cheaper end wood with ideally maple finish?
    cheers
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Real Maple will cost you a substantial sum. If you go for a veneered MDF/Blockboard with a maple finish you'll save a few hundred.
  3. simonoaks
    simonoaks
    Apr 8, 2007
    1,821
    48
    Dunstable
    +72
    finish is not as important as the specs, will happily compromise then buy equipment to match the cabinet, it is 10 times harder to find a cabinet than it is to chose a tv, amp , speakers and blu ray !!!
  4. Member 324728
    Member 324728
    Nov 19, 2008
    11
    Thame
    We make bespoke furniture in maple
