Gubbins
Discussion in 'Plasma TVs' started by sticker, Jun 11, 2003.
  1. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Ok decided that I'm going to get a Pio 503mxe but I'm a little unsure of all the ancillary components that I need, in fact I'm totally bambozzled
    I want to connect the following to it
    DVD - via component
    VHS - via SCART
    Dreamcast - via s-video
    Sky box - via SCART
    PC - via DVI
    I think that I will utilise an IScan ultra but I'm not sure what to connect to this and what straight to the plasma.
    What cables and converters will I need and what connects to what in what order.
    regards
    John
    :confused: :confused:
  2. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    Firstly Buy the iscan ultra. There going cheapish at the moment.
    Dvd - A set of component leads to feed into the iscan
    SKy - your need decent scart lead into a
    JS scart-YUV convertor
    & Component leads into the second YUV port on the iscan
    iscan ultra - VGA breakout cable (vga to YUV)
    (this output from the iscan then goes to your YUV inputs on the plasma)
    that sorts out dvd and sky.
    Dreamcast as you say s-video cable reqd
    PC will require DVI cable.
    VHS .......umm i wouldnt go down that road.
    this little lot is gonna set u back around £800+
    Personally i use Van-damme cables. there Very well made.
    there made to order. So make careful measurments of all lenghs required, As there priced by the metre.
  3. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Thanks mate, much appreciated:)
