gta 111 and gfx cards
Discussion in 'PC Gaming & Rigs' started by ianlecompte, Jan 12, 2004.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    hi to you all,i,ve just purchased gta 111 and it appears to stutter quite a lot,i,ve checked my gfx card and it is a 9.1 card which should be o.k,or so the game says.will i need to get a better card?if so which one will do the job.cant afford much so needs to be cheap or second hand.thanks for any help.
  2. Erpland
    Erpland
    Look for the patch and try that,
    what GFX card? spec machine?
    The game wasnt exactly a smooth conversion for the PC in the first place.
  3. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    6,749
    Doncaster
    +869
    dont know if you've sorted this yet, but you could try making sure your soundcard hardware acceleration is switched off, and in the game, use the 2d software sound option as well. I remember this making a BIG difference in performance for me.
    Dean
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    hia, its not your hardware thats the problem, like erpland said it wasnt a very good port over to the pc and you will need a patch for windows to let it run as it should
    take a look on this page
    http://www.game-exe.ru/news/2002/9/14/32099/for_print.html
    and this is the name of the patch
    Q306676_WXP_SP1_x86_ENU.exe
    install this and it should run ALOT better
    btw, you install this patch at your own risk, i have never used this particular site but my patch was called the exact same.
    any questions please ask
    cheers
    h4r7y
  5. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    thanks guys for the help,will try it over the next couple of days.will let you know how i get on.
