GT-7000 - PS3 - Surround System
richard-
Joined
Sep 29, 2008
Messages
33
Reaction score
Points
15
I am all new to projectors I am just wondering the best option to connect all these items together, what cables do I need because I notice on the projector there is only one HDMI port.
With the HDMI port I guess I could connect my PS3, how do I go about connecting the sound. :D
Thank you
What surround system is it? Its hard to recommend a connection method without knowing this.
It's an old Samsung DVD system 2:1. Until I can find a new one I am using this temp. I think it only has scart and component connections. Looking at the projector I guess I could use the component connection?
By component do you mean stereo RCA (Red and White).
With a PJ, you usually have an AV amp which you can send all your video and audio to from your sources, then from the AV amp to the PJ for video, with the AV amp switching between your sources for you.
Yes, red and white. Do I have to buy an AV amp? or is one built in the projector? :)
No you don't have to buy one and no there won't be one built in to the projector. It just easier and convenient to have one.
Do you have any other sources other than the PS3? If you don't then connect the PS3 via HDMI to the PJ and via the multi out connector to the samsung for the audio.
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
