Grundig Sky Box and Video Sender
Discussion in 'Sky Digital TV Forum' started by johndj1, Sep 25, 2003.
  1. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Simple one hopefully...
    Will the Grundig Sky Box output through the Scart and S-Vid at the same time?
    I have a JS Tech box which converts the Scart RGB signal to component for my TV, but I cannot put the Video Sender in between as it does not parse RGB.
    I'm hoping I can out using the S-Video and then convert to Scart In on the Video Sender at the same time as Scart Out to the TV
    Does this sound as though it will work?
    Dan
  2. Fernsehman
    Fernsehman
    Yes, the two sockets are separate.
    Fman
