Grundig hack info please
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Dumfy, Feb 5, 2002.
  1. Dumfy
    Dumfy
    Sep 25, 2001
    146
    Cardiff, UK
    Hi Everyone,
    My bother-in-law has just bought a region 2 Grundig GDV 520A Home Theatre set up.
    He'd like to be able to use it for R1 and R4 discs and was wondering if anybody knows of a hack that can be used with this unit at all?
    All help greatly appreciated and thanks in anticipation...
    Dumfy :)
  2. bob007
    bob007
    To convert this player to Multi-Region
    1. Press the Menu button on your remote control
    2. Press the buttons 1, 6 and then 7 on your remote control in order, one at a time
    3. Press the Mute button on your remote control
    4. Exit the Menu and insert the disc to play
    [multiregion codes
