Grundig GDV-620
Discussion in 'Blu-ray & DVD Players & Recorders' started by cliverayner, Dec 3, 2001.
  1. cliverayner
    cliverayner
    Does anybody know of a hack for this machine ?
  2. TravelHead
    TravelHead
    Jan 4, 2002
    Hack for disabling region Protection and disable macrovision.
    GRUNDIG GDV620-HT
    To convert to the gdv620-ht to multi-region, put on dvd channel and follow these steps
    1. Open the drive tray
    2. Press the buttons 9, 8, 1 and 7 on your remote, one at a time and in order
    3. You will now be in the hidden menu where you can change the region from 1 to 6 by pressing Enter on your remote control, or set it to 9 for multi-region
    4. You can also disable Macrovision from this screen
    5. If your TV does not support NTSC, you should change the output to PAL in the normal setup menu
    For further info have a look at the forums on www.dvdreview.co.uk
