Grundig GDV-220
Discussion in 'Blu-ray & DVD Players & Recorders' started by Totty, Mar 25, 2001.
  1. Totty
    Totty
    Does anyone have a hack for this newish player please? The current Grundig hacks don't appear to work.
    Let me know otherwise if you have got them to work
  2. Guest
    This hack DEFINITELY works. Remove discs from tray. On the blue DVD logo screen hold open/close, stop and forward skip on the actual player for 3 to 5 seconds. A screen will appear allowing you to select region number 1-6 and FREE.
    Paul
  3. Totty
    Totty
    Thanks Paul. None of the sites I found detailing the hack mentioned that the buttons
    on the actual player had to be used. I presumed they were handset hacks.
    Anyway, I tried it again and I'm now Region-free.
    Thing is, I only bought it to fill-in while waiting for my Sony CX-860 to arrive, chipped of course. I can now sell the GDV-220 with the added bonus of it being Region-Free.
    Thanks again
