Grundig GDS 300/310
Discussion in 'Satellite TV, Sky TV & FreeSat' started by loxxol, Aug 31, 2004.
  1. loxxol
    loxxol
    I have a Grundig GDS300/310 and for some reason I have no sound on rf2 output. everything else is fine, I have even removed all other complications by just having the digibox with just sat in, and rf2 out - still with no sound....
    Any suggestions?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Well if all the other connections provide audio (including RF1) and you are connecting directly to a TV with a proven cable and also not via a distributer or booster and the TV works on PAL I and correctly tuned to the digibox RF output with the volume not muted then it's reasonable to assume there is a problem with the RF2 output.
    A reboot or OS reload might fix the problem IF it's a software issue but more likely something has worn/burnt out in the actual hardware.
