grundig 310?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by woody183, Jun 11, 2002.
  1. woody183
    woody183
    Hello folks!
    I am upgrading my current analogue cable box for sky digital.
    A few queries though and was wondering if any of you guys could help?
    I have a home cinema projector which is connected to my av amp,i thought about getting the grundig as this has s-video out.
    does anyone know if this box will give me 5.1 surround?If not which one does?
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,327
    +662
    Only Sky+ will give you 5.1 sound, and even then only with a limited number of movies.
    Also take care with the Grundig if you are not buying a brand new one as they changed the spec to include S-Video without changing the model number so some have it some don't.
    Mark
  3. MattB
    MattB
    May 17, 2001
    189
    Essex,UK
    My GDS310 is just over a year old and has the S-video output. There is a note in the handbook: 'Fitted to GDS200/2, GDS210/2, GDS300/2, GDS310/2 only.'
    Hope this helps,
    Matt.
  4. woody183
    woody183
    thanks alot. i will look out for the /2 type
