grrrrr dirty lens
Discussion in 'Photography Forums' started by mr jones, Jul 14, 2005.
  1. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +22
    damnit my lens needs a good clean :( taken pictures all day
    good job i realised, my dads using my cam to take pics at my graduation tomorrow and i dont want splodges over my head.
    [​IMG]
    [​IMG]
    some sunset pictures over preston riversway docklands
    and
    [​IMG]
    taken as a promoshot for my flatmates music project - very rough at the moment, needs some serious work still
  2. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    My sensor needs cleaning Jamie, only noticed it the other. Going to buy the gear this week
  3. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    My camera has been on my mates telescope , had homemade pinhole lenses fitted to it and spacer rings and stuff for macro. All of which helps dust find its way to the sensor.
    Having cleaned it a few times now it does not worry me in the least. First time was scary but as you get more confident there really is nothing to it.
    Take a shot of the sky on f22 before you start and repeat after you have cleaned it to see progress. First time mine took 6 goes to get it spotless. Best so far was 2 goes.
    Blowers did not do the job for me. Swiping with a pec pad wrapped around a soft rubber chisel and eclipse fluid got the stubborn stuff off.
  4. Johndm
    Johndm
    Jan 25, 2003
    1,804
    Bedford UK
    +56
    I change lenses fairly often, and in some harsh enviroments, but not yet needed anything more than a good puff from a Giottos Rocket blower.
    Last time needed 3 sessions, ie puff/check.. :thumbsup:
    Lesser puffers don't hack it.
    Always hold camera inverted too, so dust is blown out and not just around inside
