Group buy on sub drivers anyone?
Discussion in 'DIY Speaker & Subwoofer Building' started by mojogoes, Mar 13, 2013.
  1. mojogoes
    mojogoes
    Remembered (1961-2016)
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Hi i have contacted one of the sellers from the well know sites and ive been told that if enough people are interested in buying one or a pair of the AudioBahn AW1500V or which eer brand that he has is chosen we could then drive the price down to some where near the £110 per pair or the £55 each mk for that particular driver , but we all have to agree on the same unit of his range to be able to drive down the end cost:)
    The are the choices from the seller.....
    15"
    AudioBahn AW1500V
    DB Audio T-rex15
    DB Audio Xtinct15
    In Phase PD15 PowerDrive15
    12"
    DB Audio T-rex12
    DB Audio Xtinct12
    In Phase PD12 PowerDrive12
  2. M87NER
    M87NER
    Jan 12, 2010
    657
    28
    +40
    Well we so far know im after 2 AW1500V's
  3. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    I'm thinking that i maybe should be sticking with only the AudioBahn AW1500V'S but hay ill see what sort of responce i get / have.
  4. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    If this had been a week ago, I would have had one..... I already bought the AW150T though :(
  5. echosat
    echosat
    Feb 13, 2005
    843
    46
    staffs
    +181
    I'm in for just 1 audio barn 1500 just for the crack
    Echo
  6. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    SO OK JUST ADD YOUR NAME TO THE LIST IF YOU WOULD LIKE TO
    BUY X1 OR X2 OF THE AudioBahn AW1500V DRIVE UNITS.
    1/ M87NER X2 AudioBahn AW1500V
    2/ MOJOGOES X2 AudioBahn AW1500V
  7. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    These do come in single 4ohm or dual 2ohm box don't they?
  8. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Hi ewizzy you can can either have them as is in 4 ohm mode or when wired in parallel it will then be in 2 ohm mode or in series in 8 ohm mode........its a very versitile option.......i think the hard core car audio guys go with the 2 ohm versions so they can wire them for 1 ohm amp use.
  9. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    I believe so.
  10. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    I would need either dual 2 or single 4 to present a 4 ohm load to my amp. If either of these 2 options are available I'm in :)
  11. M87NER
    M87NER
    Jan 12, 2010
    657
    28
    +40
    Think they only make the AW1500V in Dual 4 ohm.
  12. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    That's what I was afraid of. I'll wait to see if mojo says the seller can supply or not. If not then I'm out. :(
  13. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Yes unfortunately they only do these in dual 4ohm gize........
  14. ewizzy
    ewizzy
    Feb 24, 2012
    1,440
    St Ives
    +391
    Bugger. Then, unfortunately, I'm out /Duncan banatyne
  15. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Lol!! But i don't think you were ever in Duncan?:devil:
  16. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
  17. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
  18. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    stick 2 in a 120l box give them 1550w rms and they will hit 105db at 17hz but will need some eq.
    and if you go bigger will need less power like 200l needs 850wrms and will go slightly lower and need less eq.
  19. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Cheers Scott!
  20. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Come on guys is there only 2 people interest in a good deal on these.....we've already drove down the price to £70 each with out trying......if we can get another 3 people wanting x2 drivers a piece or 4 peopl who would want just the one driver i think we could get a great price plus as other people have already there isn't any other 15" driver that comes close to it at the price point which is lower atm.:)
  21. S7M0N
    S7M0N
    May 14, 2005
    666
    Northampton
    +57
    I already got my driver now :( Sorry !!! probably would of considered it as well, never thought about painting out the logo!
  22. mojogoes
    mojogoes
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Lol no problem you've chosen another great sub for sure:)
