Ground phono amplifier without turntable?
Discussion in 'AV Receivers & Amplifiers' started by mtrack, Apr 13, 2016.
  1. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    I have recently bought a Cambridge Audio AM10 amplifier and I can constantly hear a quiet humming noise. I assume this is because the phono input is not in use and/or is not grounded. Is there any way to ground the amplifier without the use of a turntable as I have no desire to use one?
    Thank you.
  2. Bbos37
    Bbos37
    Mar 27, 2016
    192
    Malaysia
    +17
    Have you tried other input?
  3. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    I notice the hum on all the inputs, its just louder on the phono input. I don't actually have the phono input connected to anything, can I use the phono input for something other than a turntable?
  4. Bbos37
    Bbos37
    Mar 27, 2016
    192
    Malaysia
    +17
    The phono in put for turntable cannot be used for other sources.
    As for the hum try earthing the amp .
  5. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    My amp uses a three pin power supply (UK style), does this not mean it is already earthed?
  6. camelot1971
    camelot1971
    Sep 8, 2011
    2,768
    137
    Somewhere
    +974
    If there is a hum with nothing connected to the amp (other than the speakers) then you have a faulty amp. Is it a new or used one?
  7. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    I will have to check later if there is a hum without anything connceted. Yes, it is a used amp so it could be faulty.
    Just to let you know, the hum is virtually inaudible when using speakers, yet when I use my headphones I can hear a constant him in the background.
  8. camelot1971
    camelot1971
    Sep 8, 2011
    2,768
    137
    Somewhere
    +974
    Do you have another pair of headphones to try? Sometimes the connector makes poor contact in the socket and can cause a hum. It could be a poor quality headphone amp too.
  9. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    Yes, I have tried a few different pairs of headphones but the issue still persists. Is there any reason why the hum is louder on the phono input?
  10. camelot1971
    camelot1971
    Sep 8, 2011
    2,768
    137
    Somewhere
    +974
    A phono input has a pre amp built into it so will amplify any existing hum. You should only ever connect a turntable to that connection though.
    It does sound like there is a fault with the amp.
  11. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    I did fear that I had received a faulty amp, hopefully I will be able to return it. Thank you very much for your help.
  12. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    So I've just tried the amplifier again. The hum is still there without any inputs plugged in. Strangely, I have noticed that when I turn the treble up the hum gets louder, and when I turn it down it gets quieter.
    Anyone got any ideas?
  13. camelot1971
    camelot1971
    Sep 8, 2011
    2,768
    137
    Somewhere
    +974
    It's broken? ;)
  14. mtrack
    mtrack
    Apr 13, 2016
    15
    United Kingdom
    Yes, I think it might be haha. Time to return it then... Its always a risk buying used equipment, might splash out on something new.
