Grond loop / Earth loop hum from Sky / TV
Discussion in 'Cables & Switches' started by consciouspnm, Jan 14, 2005.
  1. consciouspnm
    consciouspnm
    Jul 24, 2003
    Huddersfield
    I've got a Linn AV system and I'm getting a lot of hum from the speakers. After a bit of investigation I've narrowed it down to the SKY coax feeds and the TV aerial coax feed. If I disconnect these the hum goes away. Given that ground loops occur when equipment is connected to different mains supplies, how do I fix this as both Sky and the TV aerial is supplied via a distribution system which is powered by the 'landlords' supply. Is there an earth fault in the distribution system?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You should only have one earth connection on your system, and that is usually through the amp. It looks like your aerial system is connected to ground somewhere, and (since the TV and Sky box chassis will be connected together via the interconnects) it is forming an earth loop in conjunction with your amp earth.
  3. consciouspnm
    consciouspnm
    Jul 24, 2003
    Huddersfield
    The CD player, the Plasma, the Av-Processor, the 5 channel amp and the subwoofer have earth leads. In fact unplugging the plasma increases the hum. I think it's more likely the distribution system is not earthed properly.
