Grey screen availability
Spec-Chum
Simple question really.
It's stated in many places that a grey screen is recommended for a brightly decorated room, and there must be many of these so why are grey screens like hens teeth?
I've come to the conclusion that ideally i need a grey screen but struggling to find a half decent one for a reasonable price.
Of course 'reasonable' is subjective but for example you can get a white 100" screen from a popular auction site for under 80.
mojogoes
Remembered (1961-2016)
If!! you can get away with a fixed screen then the best thing to do would be to make your own , or paint a wall with a shade of "black widow" grey paint.
Spec-Chum
No go I'm afraid, it's a normal living area so the screen has to disappear when not in use.
Quality stuff like ReAct II is well over budget, but I do find the image from my white wall satisfactory so my expectations aren't too high :)
mojogoes
Why can't you just paint the wall with BW and the frame it.......or a removable fixed frame / screen.
mojogoes
Cheers Gary! The 106" grey screen I'd be interested but it has the mounts at each end which wouldn't work.............My fixings / brackets are the same as this sapphire unit
slir
mojogoes
But that would then nil and void the warranty and may obstruct / interfere with the screens movement or mechanism although I'm up for modifying most things.
Does any one have any pictures of one of these screens ceiling mounted cheers.
