galewis1
Established Member
After being blown away during a recent demo, I have ordered an InFocus 4805 projector. The projector will be ceiling mounted, but I have yet to decide if I should mount it length ways down the room, or width ways.
My room is 5 metres by 3 metres, and I have calculated (using projector central), that I would either be projecting a 200 x 112cm image length ways, or 160 x 90cm width ways.
To be honest, I think 200 x 112cm is too big for the room. My wife won't let me move the projector any closer to the screen because it will creep towards the middle of the room, which she's not happy about.
The width ways option, means that the projector will have to go far back to the wall (which is good from the wife's perception), and even then I will only be able to acheive 160 x 90cm with maximum zoom, which I know beacuse the light is dispersed more, is not an ideal situation. However, I'm hoping that given it's a relatively small image, it won't affect image quality to much? Any views on this?
Secondly, and perhaps more importantly, the projector will be used during the day (sky broadcasts) as well as the evening and although I have blinds covering the windows, there is some light creepage around the sides. From an aesthetics stand point, the wife won't let me go to any further measures to block out ambient light. Given the relatively low lumens output of this projector (750 lumens), I am concerned that the image will be a total washout. Is this a good reason to go for the smaller width ways through? I guess it would help?
Anyway, I plan to have a play with the projector when it arrives to determine exactly how unwatchable the picture might be, and then order a screen.
From what I understand on other posts, I might benefit from either a grey screen and/or a high gain screen. I have seen this one from Ellie (grey advantage electric for £462.46 160x90, or £514.40 200x112)
http://www.ellie.co.uk/acatalog/advantrange.html
Although it doesn't say what the gain of the grey material is (the normal white material is 1.2 I think), would this be a good choice? Apart from the slightly off-whites, what are the other downsides to grey screens?
Failing that, I could go for a matt white or high gain white. Opinions on gain or screen manufacturers would be most welcome. My maximum budget for a motorised screen is £600
Gary
Gary
