grey card?
Discussion in 'Photography Forums' started by squirrely, May 31, 2004.
  1. squirrely
    squirrely
    Jun 8, 2003
    583
    46
    Way out West
    +101
    hi all
    does anybody know where i can buy grey cards online?
    i've tried jessops but it looks like they dont stock them.
    can a grey card be made using normal grey paint(what shade) and a bit of cardboard?
  2. Tik
    Tik
    Feb 9, 2004
    10
    Cornwall
    what do you want a grey card for ??
    most commonly people want a 'card' for white balancing
    in which case any white card will do but you can get odd results if the
    card picks up a lot of reflected blue from the sky.
  3. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
  4. squirrely
    squirrely
    Jun 8, 2003
    583
    46
    Way out West
    +101
    i've been reading magazines and most of them seem to think you get a more accurate white balance with an 18% grey card than you do with a white,maybe this is just for digital cams,i don't know.
  5. squirrely
    squirrely
    Jun 8, 2003
    583
    46
    Way out West
    +101
  6. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    Knowing that what you need is 18% grey, can you not print your own?
    Even if your printer is not 100% accurate, it should be pretty close.
  7. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    Other nuetral tone things such as grass and tarmac can be used. Not intended for the kit bag though
