Grey bars
Discussion in 'Plasma TVs' started by kananga, Aug 18, 2005.
  1. kananga
    kananga
    I have a Pioneer pdp 435. When I watch tv in 4:3 I have a grey vertical bar each side of the picture. Does anyone know how I can darken them so they are black?
    Probably an easy solution but I'm not that bright.
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,710
    Galactica C.I.C.
    +223
    OK, this option is avalable so as to help against screen burn.
    In the set up menu of the tv /user settings/ picture setting ect. there should be an option that says side bar and then an option to make it dark or bright.
    Dave.
  3. kananga
    kananga
    There is a setting to have either fixed or auto side bar settings, but no adjustment for the fixed setting. (that I can see)
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,710
    Galactica C.I.C.
    +223
    Strange. You can adjust them with no problem on my Viera plasma. I would have thought you could do the same with yours. Hopefully some one else with this make will reply later.
    Can I ask, have you checked the manual that came with the TV to see if you can do anything about it?
  5. kananga
    kananga
    I can't find it. Told you I wasn't very bright!
