GREMLINS in the picture!!
Discussion in 'Movie Forum' started by BrynTeg, Dec 10, 2000.
  1. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,214
    167
    Cardigan Wales
    +2,025
    I had Gremlins bought for my birthday,it is part of the new 12.99 range,after watching it tonight i was amazed to see that some of the scenes were full of scratches and dust,the picture on these scenes was terrible,why don't they clear them up for dvd?????????????????Other than that this is the best xmas movie made...
    http://iamadvdaddict.homestead.com/dvdlist.html
  2. Colonial Marine
    Colonial Marine
    Dec 8, 2000
    37
    London, Uk
    Many thanks for the tip off, I assume this is the region 2 (or is that region poo?) version?
    I bet the region 1 transfer is better quality.
    I wonder if HCC would consider running a list of the poorly transfered discs.
    PS I bet there a loads of cr*p region 1 transfers as well.
    I say we take off and nuke the entire site from orbit.....it's the only way to be sure.
  3. Guest
    Because it made by Warner R2, who just copy the dvds from the old 1997/98 masters used fro the R1 dvds and then stip all the extras and even make unneeded cuts (Enter the Dragon)
  4. h0l1yw0od
    h0l1yw0od
    Nov 16, 2000
    477
    +13
    According to the Studio Day report at www.dvdfile.com Warner are re-releasing some of their original disks as special editions next year and Gremlins is one of them.
