Green tint with Tosh 520E via RGB
Discussion in 'Blu-ray & DVD Players & Recorders' started by DownToTheBone, Feb 6, 2003.
  1. DownToTheBone
    DownToTheBone
    Nov 20, 2002
    156
    London
    +4
    My Tosh 520E just started displaying a green tint on my Panasonic 28PK10 telly (on DVDs and the setup screen). It was fine previously. It happens thru the RGB connection only. If I switch to normal 'Video' in the setup the colour returns. I've checked the telly with my other RGB sources (PS2 and cable box and they work fine).
    Any ideas?
    DTTB
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,134
    83
    Over the Hill & Far Away
    +119
    Sounds like a dodgy RGB cable or the socket on the DVD or TV. I have had this before.. turned out the scart was not fully in the TV socket and so you got a lovely green tinted screen.
    matt
  3. adi
    adi
    same here - scart socket was not fully plugged into the tv - bit of fiddling and some coarse language and it was sorted
    adi
  4. DownToTheBone
    DownToTheBone
    Nov 20, 2002
    156
    London
    +4
    Thx folks ... it was indeed loose scart plug (into the DVD player).
    DTTB
