Green tint on Toshiba
Discussion in 'General TV Discussions Forum' started by steve35, Sep 24, 2001.
  1. steve35
    steve35
    My Toshiba 32ZP18P displays a definite green tint on Sky broadcasts. <br />I noticed that the colours weren't very vivid and that there was a green tint. I switched to the signal coming from my old aerial on the roof and although the signal was poorer the colours were more vivid and the green tint was gone.<br />Any explanations?<br />(My digibox is an Amstrad and the length of cable from the dish to the tv is longer than normal if that makes a difference.)<br />Cheers<br />Steve.
  2. Doubledoom
    Doubledoom
    Check the scart cable is connected correctly. If the RF output is fine but the scart isn't, this is the first place you should look
  3. steve35
    steve35
    Thanks Doubledoom,<br />Scarts were connected ok, but I swapped them about and now get a much brighter, not green, picture! Must have been a rogue scart.<br />Cheers,<br />Steve.
