Green Spots/trail appears with Denon A1XV...
M
monotone
Hi... just got myself the Denon A1XV
When connecting the HD plasma & DVD via DVI, the picture has green spots and trails in the brighter part of the picture...
Did I set up anything wrong?
Cheers!
binbag
You got sparklies! How long is your cable?
M
monotone
Cable is only 3m... previously used with my powerbook-plasma via DVI (same cable) no prob.
Still the cable's fault?
binbag
Possibly (& its the easiest thing to swap out). What is the display and what resolution are you trying to show?
M
monotone
Tried various output... (pref 1080i) since that's what the Plasma's DVI is for (1365X768)... but all showed green spots/trails in the bright areas of the picture...
M
monotone
Just watched it on component and it's total fine... any other ways to rectify the DVI problem? even with green spots/trails, the picture via DVI is a pretty huge improvement over component... help! :)
binbag
Which model plasma?
binbag
I'd say try another cable.
M
monotone
Dealer gave an audioquest DVI... no change. Fustrating that the mac DVI worked perfectly with the plasma, and a top range DVD player doesnt. Anyone experienced similar prob?
binbag
Try asking in the plasma section. Maybe somebody has had a similar experience.
M
monotone
Kind of a relief, the player has been found faulty. To be replaced by Denon with a new player.
