Green Screen with Cambridge Audio DVD55
Discussion in 'Blu-ray & DVD Players & Recorders' started by Waser, Jun 28, 2004.
  1. Waser
    Waser
    Mar 1, 2004
    1,059
    Purley, Surrey
    +86
    I am having some problems with the scart RGB output on my new Cambridge Audio DVD55. Whenever I select RGB output the image goes green. I am feeding it into a Panny TX32LXD1 and tried both scart inputs to see it wasn't the TV (I have sky and games consoles attached with RGB connections and they work fine) so it seems to be a problem with my DVD player.
    I intend on connecting the player with Component leads soon anyway but I was wondering if anyone had a solution to this problem?
    :lease:
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,245
    2
    +3,772
    Heard of- yes, solution- no
    Some TV's seem to respond very badly to the Cambridge RGB setting. Their engineering Panasonic is fine but our Loewe Mimo goes fairly green when switched to RGB with a 540D. I am afraid I have no idea why, my JVC is unaffected so I've never really pushed it.
  3. Waser
    Waser
    Mar 1, 2004
    1,059
    Purley, Surrey
    +86
    :thumbsdow Not good...
    I am probably gonna return it anyway. Not too satisfied.
