Green screen problems!
Discussion in 'Cables & Switches' started by chuffster2005, Dec 30, 2004.
  1. chuffster2005
    chuffster2005
    Dec 27, 2004
    543
    28
    +48
    I`ve purchased a rgb to vga cable for my plasma tv.I`ve set my dvd player to rgb,but all i get is a green screen.What am I doing wrong???
  2. chuffster2005
    chuffster2005
    Dec 27, 2004
    543
    28
    +48
    UPDATE-I`m trying to connect the following-DVD Player(with composite output)/DVD recorder(same output)SKY Plus/PS2/X Box-these are the connections I have on my new plasma.Please could someone tell me the best way to connect em all!?!
    Input Signals RGB - 50XM3
    (VGA, SVGA, XGA, SXGA, UXGA / W-VGA, W-XGA); NTSC: (3.58 / 4.43); PAL: (B, G, M, N); PAL60; SECAM; HD; DVD; DTV
    Input Terminals RGB - 50XM3
    RGB1 (Analogue) mini D-sub 15-pin x 1 (shared with RGB 1 output, selectable)
    RGB2 (Analogue) 5BNC x 1 (Y / Pb(Cb) / Pr(Cr) input of 5BNC and common use, selectable)
    RGB3 (Digital) DVI-D 24-pin x 1 (not compatible with analogue input)
    Input Terminals Video - 50XM3
    Video1 BNC x 1 (shared with Video1 output, selectable)
    Video2 RCA-pin x 1
    Video3 S-Video: DIN 4-pin x 1
    Input Terminals HD/DVD/DTV HD1 / DVD1 / DTV1
    RCA-3pin (Y, Pb(Cb), Pr(Cr)) x 1
    HD2 / DVD2 / DTV2 = 5BNC x 1 (RGB input of 5BNC and common use, selectable)
    Input Terminals Audio - 50XM3
    Stereo RCA x 3 (selectable)
    External Control D-sub 9-pin x 1 (RS-232C)
    Wired Remote Input Terminals 3P plug
    Wired Remote Output Terminals 3P plug
  3. CfP
    CfP
    Definitely make the most of all RGB/componant inputs that you can, esp from sources list DVD, DVD-R and Sky+ (if available).
    After these basics are hooked up, determine which of the others you'd like to extract a better picture from (XBox or PS2) and hook them up. Hey, if you've got enough points, then hook em all up with RGB, why not!
    Avoid composite if you can as it really does bleed colours.
    CfP
