Green screen on plasma
Discussion in 'Nintendo Forums' started by lpro, May 31, 2003.
  1. lpro
    lpro
    Tried searching through the threads but could not find a solution.
    I need rgb to the vga(through a converter) on my plasma. I bought a joytech cable, but just green screen. I also need to digital opitcal cable.
    you guys got any ideas?
    cheers
  2. mikeq
    mikeq
    Which games console?
    Which Joytech cable?
    Which RGB/VGA convertor are you using?
  3. lpro
    lpro
    Thanks for the reply Mike. Manage to get the answer on the plasma forum.
    T'was for the xbox into a pany 5 plasma. I piggy back through the sky box in the end.
    I am now on xbox live. WWWAAAAHHHEEYYYY
  4. De|ta
    De|ta
    there is way of fixing the green screen without doing that, but you'd loose live. You'd need the console chipped and running a VGA enabled BIOS
